hi, i am installaing a hot tub, i have installed a 32a mcb at the db and run a 3 core swa in to a junction box which contains a 40a rcd, the tub is second hand therefore has a swa coming from the tub already connected, after powering the circuit it tripped the main rcd in the db and will not stay energized, im aware that the 40a rcd is higher than that of the primary mcb rating and that it is poor discrimination but did not think this was that major of a problem that it would not even allow circuit to be turned on, any ideas?
