Must be a troll, surely?
No just a flabbergasted rgi.
I meant the original poster, not you! I too am flabbergasted!
Exactly - that's what I find myself having to write quite often in this forum.I am NOT advocating that people do things they do not understand or work to a lower standard than is appropriate. I never have and never will. BUT if a person is determined to do it whether or not I help then in the majority of cases offering help can help avoid a total disaster.
I will admit that I am more inclined to support your view than I was a few weeks ago because there seems to be, lately, more of a predominance of posters who clearly do not have the first idea of what they are doing let alone electrics.Disagree - always have and always will.
1) People must not work on things they don't understand, and must not be encouraged, advised or helped to do so.
2) A DIYer must not work to lower safety standards than a professional, and must not be encouraged, advised or helped to do so.
By helping them you are advocating that they do it.I am NOT advocating that people do things they do not understand or work to a lower standard than is appropriate. I never have and never will.
By helping them you are advocating that they do it.Exactly - that's what I find myself having to write quite often in this forum.
Then that is entirely due to his malfunctioning mind.In the case of this thread, it was apparent that the job had more-or-less been completed, so it was quite clear that turning back the clock and getting the work re-done professionally was not going to be an option in the OP's mind.
Yes there was - tell him not to do it.As I wrote to him, undertaking the work without an understanding of how and RCD works (and making a mistake as a result) is clearly far from ideal, but there was no realistic option to helping the OP on this occasion.
To advise, help, and teach.what, therefore, is the purpose of the forum?
I wish I knew....Also, what is it about electrics which makes people think they can do it with NO knowledge when they would not dream of attempting repairs to the gas system or even their plumbing or their car?
No one can force the un-informed DIYer not to take on the task unless one can physically remove the tools from the person.
In the case of this thread, it was apparent that the job had more-or-less been completed, so it was quite clear that turning back the clock and getting the work re-done professionally was not going to be an option in the OP's mind. As I wrote to him, undertaking the work without an understanding of how and RCD works (and making a mistake as a result) is clearly far from ideal, but there was no realistic option to helping the OP on this occasion.
Having said that, I have, for example, seen a good few 'competent' electricians suggest that a 30 mA RCD limits current flow (e.g. through a human body) to 30 mA - so I would similarly question whether they should be doing electrical work!
Kind Regards, John.
You are advocating a lower standard. Being a DIYER does not absolve this guy from the need to test. When he posted he had an incomplete circuit. Now it has electricity flowing, but we have NO IDEA if it's safe.
On the subject of regs.....
I'll not be trying to sell in the near future and so the certification isn't an absolute must. .
I was, as I'm sure you really understand, talking about the 'physical' work and I can but refer to my words which you have cited in bold red text above - if you seriously believe that the OP was ever going to do anything other than get the installation working himself (by obtaining advice or, failing that, by trial and error), you must have had very different encounters with human nature than I have!If you belive that installing a CU is just a case of fixing the box to a wall and connecting 2 ends of the feed together with whatever final circuits he has installed, then yes the job is more-or-less-complete....In the case of this thread, it was apparent that the job had more-or-less been completed, so it was quite clear that turning back the clock and getting the work re-done professionally was not going to be an option in the OP's mind. ....
I agree entirely, but again can but refer to my words which you have cited in bold red text above.However, this installation could be lethal. There is a reason we test. The fact the light comes in just means there is a supply. We don't know what will happen if a fault occurs.
It is relevant if one says (as I did, to the OP) that a person who doesn't understand how an RCD works should not really be installing one, since there shouldn't be one rule for non-electricians and a different one for electricians - my comment therefore applies as much to electricians' as to non-electricians. I certainly wouldn't let an 'electrician' who knew how to use an RCD tester but didn't know how an RCD works anywhere near my electrical installation.As for the reference to electricians, that serves no purpose in this thread. The test on an RCD is done with a suitable tester, not by somebody cuttiing a cable.
If you advise him to stop messing with things he doesn't understand, and get an electrician, and he chooses to ignore that advice, you are not complicit in him continuing to mess with things he doesn't understand.I was, as I'm sure you really understand, talking about the 'physical' work and I can but refer to my words which you have cited in bold red text above - if you seriously believe that the OP was ever going to do anything other than get the installation working himself (by obtaining advice or, failing that, by trial and error), you must have had very different encounters with human nature than I have!
Asking a question inevitably indicates a lack of knowledge and/or understanding. If you believe that every question should be answered by advising that the person should not be messing with something (s)he needs to ask questions about, you might as well close this forum immediately.If you advise him to stop messing with things he doesn't understand, and get an electrician, and he chooses to ignore that advice, you are not complicit in him continuing to mess with things he doesn't understand. If you give him any other advice, or instructions on what to do, you are complicit.
I believe you would not be considered complicit if the advice given included good reasons why the DIYer should follow the advice and not do the work as a DIY project.If you give him any other advice, or instructions on what to do, you are complicit.
