on the inside i have the vent cover,will it be ok to remove the vent cover(grill) and fit the fan there,save me making another hole and ruining the fully tiled wall?
3-4 FEET AWAY FROM SHOWER,ON THE SAME SIDE OF THE SHOWER,AND ABOUT 2 FEET HIGHER THAN ME WHEN IM STANDING IN THE BATH
Do want one with a timer,that runs on after the lights are turned off and turns on when lights turned on never brought a fan before so no idea what to look for......what about the watts ???? The one below suitable? on e-bay by ''FANTRONIX''
Easy to retrofit into existing 150mm dia hole, no need to cut a big square hole in the wall like similar fans available.
Quiet running, only 37 dB(A) @ 3m!!
Back draught shutter included as standard.
Suitable for zone 3 bathrooms (see below) and can be wall or ceiling mounted.
Standard & Humidity versions available for our eBay shop.
ABS wipe clean plastic body.
240Vac, 24watts and moves 265m3/hour of air.
