Hi all, need a bit of advice in routing of our drain from our ensuite to the foul drain, which is, per usual, on the other side of the house.
I have 2 options.
1) Sanishower pump through roof space. I personally am not a fan of this option, as I have heard they can be an absolute b*gger if they stop working. 200 quid plus for effectively a water pump is a bit steep also, not to mention having to install another circuit to my CU. I was hoping I had finished with the electrics!
2) 40mm routed round to the foul which is on the other side of the house. This is my preferred solution, although a very long run of 40mm would be far from ideal. I am also unsure of whether I can get 40mm tees in order for me to rod the drain if we get a blockage. This solution would also require running the pipework through the conservatory walls. crappy diagram below.
[GALLERY=media, 38388][/GALLERY] [net]
I know the gold plated solution would possibly be a new 110 foul drain, but it is going to be an absolute b*stard to install and would involve lots of faff, including digging up patio etc.
What would people suggest as the best solution?
I have 2 options.
