Right folks, bear with me!
2 yr old house, no space left in the Wylex CU to add a MCB for a shower-
From R-L it reads
Main (RED) RCD Switch:1-Cooker 2-Immersion one 3-Heating 4-Bell+Smoke
From there there's another RCD that controls: 1-Utility+Downstairs Bed Sockets 2-Upstairs Sockets 3-Downstairs Lights
From there there's another RCD that controls: 1- Kitchen Sockets and Lounge 2-Upstairs lights 3-Immersion two.
How could I go about fitting an instant shower when there's no more room at the inn so to speak?
I don't get the "Heating" one- we have two immersion elements, hot water is also provided by a solar panel and a multifuel stove- maybe it's the solar stuff?
There's physically room on the board(plywood one) to put in a Henly block and a new CU, but I know under current law I can't legally do this...
In my last flat I plumbed in and wired in the shower, this included "retrofitting" the CU to take a newer MCB(had to cut the busbar etc add a wire to the main supply to connect to the more modern MCB which was physically bigger than the old ones, was a few yrs ago but worked perfectly.
To free up this space for the shower(40A) MCB I had to "splice" the wiring for the fridge and washing machine into one MCB, both had minimal draw combined so there were no issues and I marked the CU clearly.
So, on that note could the bell and smoke circuits be combined and jacked into another MCB or is this just a no no these days?
A sparky I worked with recently said all new builds in Scotland should have 25% spare capacity in the CU....
A new CU/Block looks by far the easiest and neatest solution- what grade of wiring would be correct? 16mm2 or 25mm2
Any advice appreciated- If it needed a new CU then I need to get it done legally or my house insurance is invalid- but if I fit the shower to the wall, plumb it, and then make all the route clear to run the 10mm T+E from the CU how long should a competent sparky take to make the connections etc? we're talking a run of 6m through one stud wall.
Ta!!!
From R-L it reads
Ta!!!
