Good evening.
Apologies if my query is basic, but my husband has been in a bit (read denial) that this is an issue. I think it is because he fears it will be a big job to remedy. But it is totally doing my head in so I thought I would seek some advice.
When we bought this house 6 years ago the plasterwork was poor and there was a slight damp patch where this big problem has now manifested itself. We took the plaster off and back to brick, the plasterer said he had done whatever it needed for the walls to be damp proofed, can't remember what he said.
As you can see from the pics, there is blown plaster, clear damp on the walls.
This is an internal wall apart from the corner which is internal then external.
Looking at advice on here, the airbricks are not blocked, I can only assume the problem can be coming from the chimney that is still present but capped off, the chimney breast has been knocked out way before we moved in both in this room and the bedroom above. There is no problem on the wall in the bedroom nor on any other rooms or walls in the house.
Where should my investigations begin, what am I looking for. I guess if it is the chimney the loft is the obvious starting point.
If I have leaking flashing what are the signs.
Sorry to sound so numptyish, but I am determined to sort this problem out if only to prove a point (childish I know)
Edited to add: I forgot that I had posted about this when we first bought the house. Just re read my post from back then
Thanks in advance of any replies.
View media item 40308 View media item 40309 View media item 40310 View media item 40311
