Amplifier Crackle
3 Jun 2007
N East
I have a Sony Legato Linear amplifier (OK it's very old like me !) which has developed a crackle now and again. This seems to originate from the volume slider. Was wondering if there is a fix for this, I think I recall a spray to tackle it from the outside, if not is it possible to dismantle the case etc.
I'd definitely go with dismantling the case before you start spraying anything inside an amp. You want to get the fluid where it's needed rather than missing and just making a horrible gunky mess.
Contact Cleaner (A.K.A. switch cleaner is the stuff you want)
He said it's a slider so it's easy to squirt WD-40 inside the potentiometer. Use it sparingly. No dismantling required. Should be good for a few more years.
I wouldn't use switch cleaner. It will remove all lubrication and make it worse in the long run. I don't even use it for cleaning switch contacts. They really need a film of grease or oil to prevent oxidation.
In the past I have cured crackling volume controls, by dismantling and rubbing a soft pencil over the tracks, worked a treat.
Wotan
whats wrong with a switch cleaning lubricant then?
works well for me, I use this, and just normal IPA for other, non lubracative (is that even a word) , uses (which is all "switch cleaner" seems to be anyway
I think I've used switch cleaner on this in the far past but as I can't find it at the moment I've used WD40 (which every-one has to hand !), it really has sorted the problem.
It's probably fine but it's generally not available locally (unless you have a "Maplin's" store nearby) so it's going to cost you between £3 and £5 plus postage. WD-40 at around the same price, dependent on can size, tends to be easier to obtain locally and most people have a can at home. It contains a petroleum based degreaser and a light oil.
