I have lots of books, so I have lots of bookcases. As a result, I have two bookcases that block access to mains sockets.
It's occurred to me that there's about 10mm clearance behind each bookcase, so: can standard 13A plugs and sockets be got which are that low a profile? I know I can get a socket that only stands 1-2mm proud of the wall, but plugs seem to start at around 20mm. Any suggestions?
Alternatively, are there any other connection systems that have a lower profile and will fit a standard back box? (I'd want more than 2A, so not a clock connector.)
Failing that, is there actually any problem with sticking a trailing socket on some flex attached to an FCU? It'd be peculiar and I've never seen it done, but I can't see why it would break any rules or be unsafe.
