hi there, i wondered if someone could give me an idea how much an electrician would charge for labour to replace a consumer board with a new one. boards cost about 80-100 , but Ive no idea the cost to fit it up . thanks
Some do.boards cost about 80-100
And is the wiring safe?
Able to be used with a new CU?
i can see your point , so on that basis no one would probably upgrade as it will be a never ending job the way you have stated. If old wiring goes into an old consumer board mem 2000 surely it will go into a new board . The only reason he said to upgrade is because half the board or more are fuse carriers , and the other half mcb and they should all be mcb or better in his opinionSome do.boards cost about 80-100
There are also some which are less than that, and plenty which are a lot more.
Labour costs - this is not just for changing the unit, as in virtually every case, some other work will be required as there will be items which also need to be upgraded.
All of the circuits need to be properly tested as well, which may reveal other minor items which need to be fixed.
You should have said earlier that you'd already run a full set of continuity, insulation resistance, polarity and EFLI tests on it.i HAVE NO REASON TO THINK IT ISNT SAFE and it isnt suitable wiring.
OK - as I see it there are 2 ways you can proceed.the electrician looked at it and said he would replace it with a new board/consumer unit and then the labour would be 200 . You guys seem to be putting obsticuls there when all i want to know is how long would it take to remove an old board and rewire up a new one supplied at say 90 quid on top . Is 200 alot for the labour ? If its half a days work then its too much . Even if its a full day its too much. Electricians / 150 a day max outside london area ?
Just because you have fuse carriers does not mean that your installation is unsafe. All it means is that you are not compliant with the current regs .......
Sounds like you wouldnt do it for 200 quid then . i know you have expenses but so do plumbers decorators carpenters and i thought maybe wrongly that plumbers might charge 250 a day ( a day not on hourly rates) a decorator maybe 120 and a chippy 150 with an elecrtrician at about 150 aswell . If its half a days work then 200 is alot or not ?You should have said earlier that you'd already run a full set of continuity, insulation resistance, polarity and EFLI tests on it.i HAVE NO REASON TO THINK IT ISNT SAFE and it isnt suitable wiring.
1) You can keep on arguing here until someone posts a figure which you think is reasonable, at which point you can go back to the electrician, tell him what you were told, and expect him to agree.
2) You can get some other quotes from other electricians.
Which do you think is most likely to succeed in getting the work done for the right price?
What analysis have you done which shows that £150/day is enough to pay for a private pension (no employer contributions, remember), a van, tools, registration costs, insurances, accountant's fees, advertising etc, and leave enough to live on?
i HAVE NO REASON TO THINK IT ISNT SAFE and it isnt suitable wiring. the electrician looked at it and said he would replace it with a new board/consumer unit and then the labour would be 200 . You guys seem to be putting obsticuls there when all i want to know is how long would it take to remove an old board and rewire up a new one supplied at say 90 quid on top . Is 200 alot for the labour ? If its half a days work then its too much . Even if its a full day its too much. Electricians / 150 a day max outside london area ?
he just said it was old CU and needed updating and he would do it for 200 plus cost of new unit.
