I have just bought a cooker hood from wickes.
A few questions that i have.
The hood needs to be wired to a 3 amp fuse,the flex is is 2 core live and neutral .On my wall above the worktops there is a double socket near my cooker control unit.Can i put a 3 amp fuse in a normal plug and wire the 2 core to the live and neutral of the plug (hood is double insulated as theres no earth on the flex) and just plug the hood into the double socket ?
Also the flex is a little short ,is it ok to replace the flex for a longer one,i am assuming this should be fine.
Also cause i am using an existing outlet ,is this still notifiable ??
Thanks in advance.
Thanks in advance.
