Ideal Icos m3080 fuse blowing
Status
Not open for further replies.
27 Nov 2005
Berkshire
I have an ideal boiler which is now three years old. The mains fuse has blown. In order to check the controls, I disconnected the boiler mains input, replaced the fuse and all of the external controls appeared to work. The programmer came on, turning on the HW and CH controls on the programmer, resulted in calls for heat from the boiler. I reconnected the boiler and the fuse blew again. This time I removed the control wire to the boiler, and replaced it with a link as per the Ideal wiring diagram. The fuse blew again, so I am sure it is a boiler fault. With no mains there is no Fault code, any ideas anyone? I called Ideal, but their customer services will not send anyone out "unless it is warranty work".
This is a long shot but is there a resistor screwed to the chassy somewhere ??? as if this has broken down it will cause the fuse to blow, as I said a long shot but worth 5 mins looking, if there is unscrew it from the chassy and try again.
Have had the fan and gas valve blow fuses on these boilers(normally internal fuse on pcb 3.15A quick blow), resistsance on fan should be about 115 ohms on the red and blue terminals that feed fan. the resistor is a capacitor that sits by the condense trap (can blow fuses if breaks down) . Also had the condense trap leak water onto the capacitor( due to crack in casing .)
I have a similar sounding problem on my Ideal Response 120 - Ideal have told me it's most likley to be the low water pressure switch that needs replacing.
(There's a thread posted on here under the title "Ideal Response 120 ...fuse keeps blowing" that you may find useful
Alex
disconnect mains on pcb then turn 3amp fuse back on that way your pooring its the boiler,also check for a slight melting around the 10 way morlex thats where pump,fan come back in.very good chance its the pcb.
Status
