Cutout
31 Mar 2006
Leeds
It's a bank holiday, and I was bored so I thought I'd change my cutout.
Old cast iron cut out
Open her up
Remove the fuse and disconnect the tails
Open the bottom bit. This was a bit stubborn so had to warm it with a blow torch.
Cover off
Remove the old fuse holder and neutral block. I covered the live with the end of a pyro shroud.
Remove the back of the cutout
Break off most of the pitch and remove the insulators. Again I had to use the blowtorch to soften the pitch in the insulators.
All cleaned up
Just need to swap positions of the line and neutral for the new cutout
Thought I had a cutout in the garage, but couldn't find it. Had to use an old fuse holder and an earth block for temporary.
Tails back in
Done :D
Not forgetting the heat shrink and the means of ensuring that the papers don't unravel
You must be brave to attempt that !
Last one of them I had changed by Scottish Power the engineer sent for the digging team and cut the cable coming into the property, replaced it with a new length of split con and new Henley cutout.
You also failed to include details of the checks you must carry out prior to starting and upon completion
I assumed that RF had come across a board and cutout after a mains upgrade, re-location or demolition, and used his own meter, making the cable live and dead as required!
Looking at it though, I do wonder if his "RF" label on the meter is to simply conceal the meter serial number for traceability purposes!
