It's a bank holiday, and I was bored so I thought I'd change my cutout.
Old cast iron cut out
Open her up
Remove the fuse and disconnect the tails
Open the bottom bit. This was a bit stubborn so had to warm it with a blow torch.
Cover off
Remove the old fuse holder and neutral block. I covered the live with the end of a pyro shroud.
Remove the back of the cutout
Break off most of the pitch and remove the insulators. Again I had to use the blowtorch to soften the pitch in the insulators.
All cleaned up
Just need to swap positions of the line and neutral for the new cutout
Thought I had a cutout in the garage, but couldn't find it. Had to use an old fuse holder and an earth block for temporary.
Tails back in
Done
Open her up
Cover off
All cleaned up
Tails back in
Done
