The idea of the buffer tank is so that the ashp can build up a store
of heat ready for delivery.
Like starting at 4am for the central heating coming on at 6am.
There is a quantity of hot water that in cold conditions when the heat
pump is down on power can help to smooth out the peak demands
of the day.
So in my mind the inverter ashp will perform better when just ticking
over keeping the building warm in lower demand times.
I have a Daikin air con unit that is an inverter and it certainly works more
smoothly than my other on off cheap chinese unit.
of the day.
