I recently had a problem with my water heater. After repairing it, and unrelated to the fault, the gas engineer claimed that the pipework was undersized he said the water heater was "AT RISK" and he isolated it at the inlet valve. His report claims "The burner pressure on water heater is 11.8mb. Standing pressure = 23mb, Working pressure taken at water
heater whilst hob on = 17mb. (pipework is undersized!) Water Heater= "AT RISK" isolated at inlet valve"
I have read elsewhere that undersized pipe work should be classed as "Not to Current Standards"
"... anything which does not comply with the gas regulations but is neither ID nor AR. This is called "Not to Current Standard" (NCS).
"A good example could be when a gas pipe feeding an appliance is too small. The pressure drop along the pipe means the inlet pressure to the appliance is too low, so the appliance burns less gas than it is designed to burn (the flames are a bit smaller). This is clearly not ID, nor is it even AR, but it isn't right. Provided the appliance is running safely there is no risk, so it is simply classed as "Not to Current Standards" (NCS)."
Which one is right?
Which one is right?
