E
Exprienced
WRONG if the sensor started transmitting continuously due to fault or a non compliant design then the siren's jamming detection would be triggered and the alarm would sound. ( unless tamper was disabled ). This may be connected with the reason sensors go to sleep after reporting motion detected. If they transmitted continuous reports then sirens in the area would go into tamper ( jamming ) alarm state.A neighbours sensors would never set off your alarm.
EH!!!
But the Yale is a compliant design!!! you are now talking about a totally seperate issue which is now aparently a malfunctioning pir transmitter.
The sensors go to sleep to save battery life not to prevent jamming issues..
Bernard you are an intelligent guy but you lose all reason when talking about Yale alarms.
BTW you don't disable the tamper system to prevent jamming false alarms you disable the jamming detection response.
What do you want to discuss next as a hypothetical alarm failing. How about the biggest of all wired or wireless,
Forgetting to set the alarm in the first place!!!
Keep going Bernard with your obsession , I'm pretty sure you have trolled enough now to get yet another thread locked...you are a bit of an obsessive pain in the ass.
Why are you bleating on about your pet subject of potential jamming or blocking issues in this thread when the original problem had never mentioned the external siren going off or the control panel logging sensors as out of order?
