Any equipment that uses radio on a Licence Exempt frequency is going to be at risk of being affected by other equipment using the same frequency.
If the system uses two way communication protocols between panel and sensors then almost all legal interference can be managed without compromising the alarm function. The worst that can happen ( with legal interference ) is that messages may be delayed for a few seconds until the channel become clear enough for the alarm system to pass its message(s)
What is "legal interference" ?
The requirements of the Licence Exempt equipment is that the design must accept interference from other Licence Exempt sources and still function in a way that the user finds acceptable. For this reason no Licence Exempt equipment ( in the frequencies used for alarms ) is permit to transmit for more than 10% of the time. In theory 9 systems using two way communications could "co-habit" on the same frequency without affecting the functions of each other other than delaying messages. System using one way comms would not function well in that situation as the sensors without recievers have no way of knowing [a] that the channel is clear before they transmit and no way of knowing whether the message was received by the panel.
Legal interference has to be accepted and no action will be taken against any equipment operating within the terms of the Licence Exempt regulations.
In some applications the ratio is set at less than 1%
Equipment that does not comply with Licence Exempt regulations may produce interference that is not "legal" and action can be taken against the user of such equipment but finding the source and obtaining evidence in one off domestic situations will be more expensive than installing a wired system to replace the compromised wireless system.
