- Joined
- 11 Jan 2004
- Messages
- 46,418
- Reaction score
- 3,744
- Country
Well, first chek it's nothing simple like the lamp failed. try the existing lamp in another holder so you know it's working. Then try putting the reds and the brown together again in a switch terminal and see if the light comes on. If it does, great. If not, it could be the cable to the light fitting that's faulty or the lampholder itself.
So you could disconnect the wires feeding the lampholder and connect a temporary feed from a socket (via a plug) to the fitting to see if the fitting works or connect a temporary lampholder to the existing cable to see if that works.
Very long-winded, but without a multimeter.....
