What to do with excess chandelier flex?
28 Sep 2012
Staffordshire
Hello, I would like to hang a chandelier in our living room, not a big heavy expensive one just a light weight one. Alot come with very long flexes and chain attached. Our ceiling isn't very high so I would need to shorten the chain by quite a bit. What do i do with the excess flex? I imagine it can't be cut very short? Can someone advise me please? Thankyou :?
In case the fitting ever needs relocating to a room with a higher ceiling, I leave the flex the length it was and push the slack into the void.
Thankyou for your help, much appreciated :D I just spoke to my husband and he was very embarrassed that I'd posted such an easy question on here :!: but he was outside re-roofing our house at the time so I couldn't ask him :wink:
how would this be achieved if the circuit is wired as 3 plate? Dont quite see how you can shove anything into a void?
I would just shorten the flex and if the fitting was required elsewhere just re-wire with new flex
You would terminate the cables from the ceiling with the flex to the fitting, then push the slack from both back into the ceiling void, leaving the connectors inside the rose.
It can be a real PIA to do, plus you have then altered the fitting, which may have implications.
