Cavity wall lintel advice needed.
13 Jun 2007
Sussex
Hi guys,
I'm building an extension and am approaching the top of the blockwork. The bifold doors the client has ordered are a bit bigger than originally expected and it looks like we'll have to have 2 courses of bricks on top instead of the expected 3 and a split level of blocks across the top.
The problem I have is the lintel required needs to be about 4500mm long (4575 seems to be the closest) but only 150mm high to allow 2 courses of bricks to joist height and I can't find one!
Does anyone know where I can get such a thing or maybe there is an alternative type of lintel?
You will most likely need to have a beam fabricated with a welded plate to take the outer course, specced-up by an S.E.
Thanks for the replies guys, I will post the solution when I find it.
