    Dismiss Notice
Cavity wall lintel advice needed.
Discussion in 'Building' started by pete47, 23 Oct 2012.
  1. pete47
    pete47
    13 Jun 2007
    27
    Thanks Received:
    Sussex
    Country:
    Hi guys,
    I'm building an extension and am approaching the top of the blockwork. The bifold doors the client has ordered are a bit bigger than originally expected and it looks like we'll have to have 2 courses of bricks on top instead of the expected 3 and a split level of blocks across the top.
    The problem I have is the lintel required needs to be about 4500mm long (4575 seems to be the closest) but only 150mm high to allow 2 courses of bricks to joist height and I can't find one!
    Does anyone know where I can get such a thing or maybe there is an alternative type of lintel?
  2. Sponsored Links
  3. ^woody^
    ^woody^
    3 Sep 2006
    27,803
    Thanks Received:
    3,492
    West Mids
    Country:
    I doubt you will find one that depth for that span
  4. noseall
    noseall
    2 Feb 2006
    36,240
    Thanks Received:
    2,297
    Staffordshire
    Country:
    You will most likely need to have a beam fabricated with a welded plate to take the outer course, specced-up by an S.E.
  5. Static
    Static
    20 Dec 2005
    2,026
    Thanks Received:
    168
    East Sussex
    Country:
    Agreed.. spans too big for standard lintels..
  6. pete47
    pete47
    13 Jun 2007
    27
    Thanks Received:
    Sussex
    Country:
    Thanks for the replies guys, I will post the solution when I find it.
  7. noseall
    noseall
    2 Feb 2006
    36,240
    Thanks Received:
    2,297
    Staffordshire
    Country:
    You've found the solution, just post us the outcome. ;)
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
