Told you
Square peg, round hole?
So how would a plumbers pipe cutter help score a flat cu buzz bar![]()
Scoring with a metal workers scribe, or any sharp point such as a bradawl or a Stanley knife run down the ruler edge of a set square.
But. > ZusZeil.
The busbar is FLAT
The pipe cutter is designed to cut into round pipe.
You can rub the flat busbar up against your pipe cutter thing as much as you like, but it isn't going to do anything to it, except get a bit hot.
In any case
I have no idea why you need to scribe, or score the busbar in the first place.. Just cut the bloomin thing. Or bend it a couple of times.
Good grief, why do you try and complicate everything???????
I agree totally, but ....In any case I have no idea why you need to scribe, or score the busbar in the first place.. Just cut the bloomin thing. Or bend it a couple of times. Good grief, why do you try and complicate everything???????
That isn't strictly true. Although not designed for the job, a standard pipe cutter can be quite useful for scoring flat bars (metal or plastic) up to about 1.5cm wide (wider with some cutter designs).The busbar is FLAT ... The pipe cutter is designed to cut into round pipe. You can rub the flat busbar up against your pipe cutter thing as much as you like, but it isn't going to do anything to it, except get a bit hot. ...
Any tips/gotchas/whatever-you-do-don't-do...s for cutting insulated CU busbars?
I had planned to just use a hacksaw with the work clamped either side to stop the plastic cover moving about....
