Hi DIYNot,
So I had my house completely rewired a couple of years ago before moving in. (Needed it as wiring dated from 1940s. Fancy sitting in a bath with a bare 1940s 2-bar heater dangling from the ceiling over your head?)
The electrician seemed nice at first (don't they all?) then his hat grew to 10 gallons. Left light switches live with so much wire bulging behind them that they couldn't be screwed into the wall - this was after we + 2 young kids moved in. 'Oh, tell your kids not to poke their fingers behind the switch. I'll sort it out later" (never happened).
Got rid of him. Council inspected wiring, seemed happy with it. Most of our lights are recessed downlight MR16 (GU5.3) 12v 50watts. 35 of em! (kitchen, living room, bathroom, hall, various alcoves etc)
Never have I seen such a shabby light installation. Bulbs blow all the time. Sockets die and need replacing. Lights flicker like mad both on full & when dimmed.
Got in a second electrician, told us all the transformers needed replacing. Charged us a grand to do it. Lights seemed fine for a while.
Now they are flickering & failing again. Two transformers were blown. I replaced them myself (not that hard) which sorted out the issue for these particular lights. Need your help on remaining issues:
1. Should I just rip out all the MR16 sockets & replace them with something else? With what?
2. The sockets seem to fail all the time - I seem to be replacing them almost on a monthly basis. This is a pic of what I'm replacing:
Every time I have to take the recessed fixing out, it damages the ceiling plasterboard more and more. I'm getting fed up of this.
3. Bulbs failing all the time. I have noticed that when I take a blown bulb out, almost every time one of the two pins is gleaming & the other one is deeply tarnished. Sandpaper the tarnish off & put the bulb back in, bulb half the time is working fine. What's going on?
4. Lights flickering when dimmed. All the dimmers are Aurora 2-way dimmer AU-DSP400, min 60W max 400W. I noticed the second sparky replaced a couple of misbehaving Auroras with Hamilton Litestat L400/2, min 50w max 400w, which seem fine. Should I replace the remaining Auroras with the same model Hamiltons?
Fusebox is Wylex, 2 banks of 4 fuses, + 2 RCD's. I can't find a spare transformer right now but will take one out if you ask.
Thanks for any advice.
RedMonty (Experience: careful semi-competent DIY'er, first time house-owner)
