So... heres the dilema, I'm nearly at a point of swapping over the position of a bath and toilet. I've done the following so far (and still been able to leave everything useable and in place):
sorted pipework
sorted new 10mm cable for electric shower over bath(to be final fitted by electrician)
re-boarded walls and aquapaneled walls around new bath area.
prepped new waste pipe for bath and toilet waste
As we only have 1 bathroom, i cant really afford for the toilet/bath to be out of action for longer than a weekend. so I was hoping I could tile in advance of moving the bath to save a day or two waiting for tile and grout to go off.
If i measured accurately the hight of the bath I could pre-tile the walls i need to tile, leaving 1 tile+grout+silicone gap. Then shift bath and adjust any tolerance using the screw feet before adding the last row of tiles? and then silicone the gap as normal.
The bath is going to sit tight to the wooden studwork wall and the aquapanel/tiles will sit overlapping the top edge of the bath.
Main question is does this sound feasible? and does anyone foresee any major problems that i may encounter?
Cheers
sorted pipework
Cheers
