Advice on brushes/paint combos please
26 Feb 2005
Gwynedd
Could someone piont me at, or write, a quick guide to which type of brush to use with which type of paint please?
eg natural hair+ OB gloss
Synthetic + WB eggshell
that sort of thing
It'd be much appreciated, as I have a ton of deco work on my house to do!
To make it simple the rule is don't use a bristle brush in acrylic paint but you can use a synthetic or bristle in oil based.
Purdy are a good all rounder, you can apply emulsion, WB and OB top coats to a really good standard.
Picasso are very good for WB and cut a good line when emulsioning and hold a lot of paint, havn't used in OB
Wooster FTP are popular amongst a lot of dec's but havn't used them myself.
Corona are excellent but not yet available in the UK, the best i've used for applying acrylic u/c and gloss and satin, you may be able to find them on ebay, cost me a lot to import from the states.
I don't like hamilton, blue purdy, harris and generally any cheap brush but do keep a couple as a throw away option for stuff like bin.
I don't mix mediums i have WB brushes and OB brushes. If you're going down the OB route it would be worth getting a brush mate 4 for storage.
Acrylics, dampen the brush before use and clean it periodically if using for a long time to stop dried paint forming above the ferrule. Crud cutter do a good brush restorer/cleaner.
Adding floetrol to WB and owatrol to OB keeps the paint open longer and eases application.
If your not a pro that earns his money from his brushes i'd say go with a purdy box set of monarch elites because they do everything well. Probably wouldn't bother with bristle because until they're worn in they shed a bit and the tips break which is annoying. If your going to go all WB'd i'd buy a 3 inch, 2 inch and 1and a half inch picasso.
Your welcome.
Ask ten dec's their favourite brush and you'll probably get ten different answers but its good to understand if you use the right brush for the job you can improve your finishes.
Driving a rolls royce won't make you a good driver. It's more technique than equipment.
Well, even a great deco will surely struggle to get a good finish with a knackered old Woolies special (that dates me!). May as well get a tool that gives you the best chance of success.
Actually power steering, abs brakes, traction control, stability control, parking assist, low tyre pressure warnings etc etc makes you not necessarily a good driver but a hell of a lot better than if you were driving a mark one transit
I sort of agree with both views. Technique is vital. you could hand someone a Purdy and they would still make a right hash of things. But then quality kit can make a good technician even better.
My brush box is full of Purdy Monarch elites. OB and WB are marked and kept separate, as are brushes for colours and whites. Am a bit OCD with brushes.
Am looking forward to trying the Proform Picasso though. Have ordered a 2.5" to try out with emulsions.
You won't be disappointed, brilliant brushes, the three inch angled oval ferrule picasso is the daddy for emulsion.
