I am looking to replace a single socket with a double or triple one, triple would be good to make it more future-proof (it'll only be used for electronics so the 13A fuse won't be an issue).
I know you can buy special conversion boxes that screw into an existing single flush back box. But how are these different from a standard surface box? The former seem to have metal apertures at the back that fix to the metal back box, whereas the latter tend to be all plastic. But the fixing holes appear to be in the same place for a single flush box.
From a safety or practical point of view, is there any reason I couldn't use, for example, an MK 3-Gang surface pattress, attach this over the existing back box, and attach a standard 3-Gang socket? This would be better for matching other fittings in the room.
