I'm installing a 400h x 800w radiator in my hallway that is always freezing cold mainly because there isnt a rad at the top or bottom of the stairs.
Because of where I'm connecting into (22mm pipework above) 15mm flexible plastic pipework will be used. On the image attached I plan on dropping the two pipes down the corner. The left hand pipe should connect in fairly straight forward with the help of a 15mm 90deg elbow on the bottom of the lockshield/TRV.
1) My main question is will I be able to obtain the sweep to reach the furthest valve or will I need a 90deg elbow at the bottom of the drop and then run the pipe along the bottom of the rad to the other valve? The brackets are pretty small.
2) On this instance would it make sense to have the TRV on the left or right of the rad in that picture or does it not make any difference? I'm using John Guest pipework & fittings.
3) The john guest elbow stem - with the aid of a pipe insert can this be connected directly into a 15mm chrome compression elbow?
Thanks in advance for your replies.
