Shower on stud wall
29 Apr 2013
Yorkshire
Hi everyone I'm soon gonna start ripping out my bathroom and intend to move the bath down to the opposite wall which is a stud wall, this wall is on the landing side of the bathroom. I want to fit a shower bar using a concealed fixing bracket, will I need to insulate the stud to cut down noise from the pipes when the shower is running?
I did exactly the same. I put a mixer shower into a stud wall adjoining the landing.
I did insulate the void and I don't notice any issues when the shower is running.
You can insulate walls to reduce noise, you can also lag the pipework.
But another consideration is allowances for the pipework to expand and contract when heating and cooling down and clipping distances of pipework to avoid water hammer.
If it's wet area the use of moisture boards would be recommended or belt/braces cement boards. These can both be directly tiled onto without the need of plastering, but seal up the butted joints of the boards.
While you're doing the installation, put a temperature sensor on the hot feed to the shower, as this can be used to switch a fan on if you'd rather not have it come on with the lights, or have the user to remember, or have the cost of a humidistat one. It also means you can use a basic non-timed one, as the water in the pipe will stay hot for a while after you turn the shower off.
But then the fan will only come on if the shower is in use.
What if the toilet ( :shock: ) or bath are in use?
Better to have a PIR.
Then it will trigger in all situations and cannot be forgotten.
And if you don't want it to trigger, you can turn off the TP switch.
Don't know that the room contains a WC. Or if it does how essential a fan is.
Bath? - have the temperature sensor before the pipe branches, unless the shower control is a 2 or 3-way diverter in which case it will come on anyway.
Including all sorts of situations where you don't need the fan to come on.
And then you can forget to turn it back on :wink:
Sorry about late reply chap I've been on nights. The fan I've got has as built in humidistat, I've a plumber coming today it give a qoute for moving thingd about ,so it will be in his hands when the floor comes up if the the price is right. Thanks for your help
