Narrowing and fitting door frame to brick
19 Nov 2008
Dorset
I am moving a door frame. further back. In the jpg, from the existing position to behind the toilet, that is behind the wall on the left.
On the left is timber on the right is the brick parting wall 18" ??. Above is the loft space.
I need to narrow this opening, and intend to make a short stud wall 5ish inch. Do I need to remove the plaster? What size timber to to fit to the brick wall and what fittings needed please?
Cheers, Camerart.
Presumably you are packing out to suit a particular size door?
If so, i would pack out from the masonry side in order to accommodate the archies etc.
Fix a 100mm x 50mm timber to the masonry with 100mm screws and brown plugs (7mm drill bit). Fix another one to this but pack it off the first one using suitably sized packers in order to get your 5". You should select your straightest timber for this and make sure you upright it by using bigger or smaller packers.
Then bring down the header to the correct height whilst allowing enough room for carpet etc under the door.
Correct! I will move the cupboard door in the distance (Pine panelled with hardboard removed) and fit it halfway between where it was the near wall. This will form a shower inside the bathroom.
Thanks very much Noseall, all understood.
Cheers, Camerart.
