MK Logic Plus Grid - Alternatives
are the wine racks chilled or just ambient?
So you essentially have three distinct areas with appliances built in?
I think personal preference dictates how you do it, but I for one, would not want to splatter my kitchen with 5/6 FCUs and a cooker control switch
I guess it's just the FCU I don't like (the fuse below the rocker rather than next to it)!!.
It's not that so much that I don't like, it's the cr@ppy screw mechanism that fails on the first use.
on the fuseholder?
Mmmm.
I've never had a real problem with them, you just need to push harder than you think you should. I will agree they could be made better though
then sockets or FCU's under the counter
Does that not defeat the purpose of having the 'controls' above counter. I.e. what happens if the fuse blows in an FCU behind a built-in oven, or integrated fridge?
You'd have to pull the appliance out... at least in an above-counter FCU you just change the fuse.
If you used a grid switch/fuse combo, you'd need a 16 gang one for 8 appliances.
it does somewhat defeat the purpose, but it means you still have DP isolation above the counter for use in an emergency or whatever.
And lets face it, how many times have you had to pull an appliance out to replace it's fuse?
Somebody posted a really nice gridswitch set up on here before, I think it was RF (well it would be wouldnt it!) I'll see if I can find it
Just timber - open fronted. Effectively a 150mm wide base unit with 4 or 5 shelves and no door!
I know what you mean about so many FCUs. Got this in my current kitchen, and while it doesn't look ****, it doesn't look particularly great either.
If you put the kitchen on it's own ring, does this achieve the requirement of being able to shut appliances of instantaneously without individual appliance controls..... as you just trip the breaker in the CU :lol:
Do televisions never catch fire?
Stereos?
PCs?
Phone/laptop chargers?
Wall-warts for anything?
Convector heaters?
Stereos?
PCs?
Not entirely sure I get the reference to this entirely? All of those things generally have an accessible means of local isolation ie the socket theyre plugged into is not hidden behind a 15kg, often built in appliance.
If that's where you're headed, I'll give you a race, me unplugging my phone charger, and you unplugging your washing machine :lol:
:wink:
:wink:
I already linked to photos 1 & 3 in my previous post, no 2 was the one I was actually looking for. I just wish MK did engraved switches with labels I actually wanted, don't fancy paying the same price as the switch again to get them engraved myself
The double socket in the first pic looks the same as a 'no brand' one I got off eBay - the black part around the pins is a slightly different shape
If I went the grid switch route with under-counter FCUs, how would I handle the oven as I believe the max FCU you can get is 13amp.
The oven I'm looking at is 20amp; fit a 45 DP switch below counter rather than an FCU?
