alarm call for all
Status
Not open for further replies.
mine must be more secure than yours, then
are your PINs restricted to 4 digits, like he says?
Honeywell, buys up anything and everything. The panel described in the video as Honeywell is in fact an Ademco Vista 4140, NOT a Galaxy.
Ademco, now owned by Honeywell, Galaxy now owned by Honeywell, the list goes on.
Galaxy can have 4, 5, 6 digit codes, take your pick.
I suppose all you experts know that continually trying different numbers to find the code will activate a Galaxy or most, if not all of all makes, whether alarm set or not.
It's all in the heading.
4140 Ways Your Alarm System Can Fail Derbycon 2012
The hardware/software is the same ;)
He did say "I'm going to talk about Honeywell Ademco systems" 2.24
Try 3 wrong codes in a Yale and the keyboard locks out for one minute. Add in the fact that the panel should be in a protected zone and you have failed and the alarm has gone off.
Like I said, Honeywell owns Ademco, He was playing with an Ademco Vista 4140.
Ademco, do you know what that anachronism stands for?
Alarm Device Manufacturing Co
How on earth can all the hardware /software be the same when made by different companies in different parts of the world?
Many items, not just alarms, are reverse engineered to obtain the circuit diagram. Then the circuit is laid out on a new PCB layout which looks different to the original as the components are in different placesl but is functionally a direct copy. Maybe a few changes to components to make it look "really" different.
  • Thanks
Reactions: dpt
Well, one thing I can assure you of here is that other than being intruder alarm panels that is where the comparison ends.
Also, there is no need to be patronising
Status
