Is this (the NIC's question) not the point which EFLI and I have been making? If this were allowed for main bonding (and I confess that I have yet to find anything in the regs which says that it isn't), then every water pipe which entered 'on the other side of the building' from the MET would surely be (wire) bonded close to the MET, regardless of how far that was from the extraneous-c-p's entry into the building? As I've said, I really do doubt taht the regs intended to allow that!...The water bond was done at the stop tap, and then just lugged to a bolt through a steel column. This was within maybe 15m of the mains intake, so lazy. The NIC pretty much said "what if it was the other side of the building, would you expect a cable run back then?". This is when he brought up the use of an extraneous part. I had always known about this for supp bonding, but had always assumed it was not permitted with a main bond.
