I am building a computer controlled boiler system, so that I can remote control my boiler as well as put in more advanced scheduling (including weather compensation). At the moment I have a Drayton wireless thermostat via a Drayton SCR.
My system will be a Raspberry Pi with WiFi controlling a USB relay. For this I have a spare SCR and thermostat to test with. So, I can build without freezing my house when it goes bang!
The main question I have is about "Volt Free Contacts" and how the Call for Heat (CfH) works. Probably best to have a look at my planned schematic ...
My plan is that if I can revert back to the normal system by simply powering off the raspberry pi. The first relay will control the thermostat which will be open (NO) during pi control and auto switch to NC when powered off.
So, does the CfH pass current? My relay is rated to 250V and 10A.
Does this all look okay?
I am thinking of building a test circuit using a couple of bulbs to emulate the system. Any ideas on that? I guess it depends on the CfH voltage answer?
I am wary of fiddling with power, but am happy enough that the relay will be okay with what I am planning. Of course, I could stand corrected.
