R
richard7761
Don't worry, I am very safety concious. :c)
I have a motor and gear arragement from a circular saw. It's soft start and I can adjust speed. It is rated 1450W.
The blade that came with the saw is 210mm and 12T, max 7000rpm. (dia 210 x 5/8" 2,6 x 12T)
In order to clean cut regular wood to 100mm depth I'd need a blade 260mm diameter. They probably don't make blades 260mm dia., so I think I may need to go for a 300mm dia. blade.
Will the motor cope?
Will choice of blade teeth help?
Thanks.
Thanks.
