- Joined
- 28 Apr 2004
- Messages
- 8,411
- Reaction score
- 1,008
- Country
Yes.So if a bit of flex was secured by one clip to hold it clear of the floor it becomes part of the fixed wiring?
So that would require a MWC
Do you mean does adding a clip require a MWC, or installing flex which you then clip at installation time?A further thought on the clipped flex scenario, if someone clips a flex does it need a MWC as it becomes fixed wiring
Once you clip it it becomes fixed.There are, of course, situations in which 'clipped flex' will be reasonably regardable as 'fixed wiring' but, IMO, that will never be primarily because it is clipped.
Are you being deliberately obtuse?That's for others to decide. As I've said, I wouldn't personally dream of considering the flex of a 'portable item' (common sense definition) as being 'fixed wiring', no matter how immovable or hidden/'protected' I'd made it!A further thought on the clipped flex scenario, if someone clips a flex does it need a MWC as it becomes fixed wiring
I agree wholeheartedly with the above![]()
Yes.When it is 'fixed'.
So if it is fixed by one solitary clip is it fixed?
I've recently been somewhat criticised for speaking of Mr Jobsworth - but, with the best will in the world....Yes.So if a bit of flex was secured by one clip to hold it clear of the floor it becomes part of the fixed wiring?
Either really, I do a lot of work in schools and they use 4 way extensions in most classrooms , quite often I see flex tied to bracket or similar with a shoelace, does that qualify as fixed
Maybe because they realise that everyday words are often used, even if incorrectly, to have meanings different from their literal/dictionary ones.Once you clip it it becomes fixed. How hard is that? Why do so many people struggle with the meanings of everyday words?
No, that's 'tied'.
Are your shoes 'fixed'?![]()
So cable(s) attached to, say, a wall by means of cable-ties and cable-tie bases are 'tied', but not 'fixed'?No, that's 'tied'.Either really, I do a lot of work in schools and they use 4 way extensions in most classrooms , quite often I see flex tied to bracket or similar with a shoelace, does that qualify as fixed
Ah. They are probably clipped direct.I wear sandals (no socks)![]()
Have you ever seen cables tied to tray with these
http://www.tlc-direct.co.uk/Products/CT100BL.html[/QUOTE]
I suspect that would be fixed wiring regardless.![]()
Sorry but yes I did. Reading the Welsh Part P in a kitchen if I was to use an extension lead then no need to notify but clip up the cable safely out of the way and yes to letter it would need notifying although I think you would be daft to do so.I've recently been somewhat criticised for speaking of Mr Jobsworth - but, with the best will in the world....Yes.So if a bit of flex was secured by one clip to hold it clear of the floor it becomes part of the fixed wiring?
I'm not even sure I understand the point of all this. Surely no-one is suggesting that, at least under pre-April rules, one might have had to complet an MWC and notify LABC when one was going to plug a piece of equipment into a 13A socket, because it's flex was attached to the wall by one clip to keep it off the floor ... or are there people who would have suggested that?!
.. but does that not beg the question posed by the title of this discussion? What you say would only be correct (albeit that most of us, with the possible exception of BAS, would regard it as totally daft) IF you believed that the 'clipping' of the flex of something otherwise 'portable' caused it to become 'fixed wiring of the installation'. Is that what you believe?Sorry but yes I did. Reading the Welsh Part P in a kitchen if I was to use an extension lead then no need to notify but clip up the cable safely out of the way and yes to letter it would need notifying although I think you would be daft to do so.
I think that would be regarded as fixed but somewhat different than an extension lead 'tied' out of the way with shoelaces.So cable(s) attached to, say, a wall by means of cable-ties and cable-tie bases are 'tied', but not 'fixed'?
