In that case shouldn't the question be directed at your new employers?yes i got the job then was told i was to do the pat testing all the new equipment is supplied but was asking about having to take a test as on the video they gave me kept mentioning a test for pa testing that is all thanks
i was given the job as handyman around the care home but was not aware that i was required to do the pat testing until 2 weeks into the job when i was handed the new pa tester and the relevant paperwork and a video to watch but my question is do i have to take a test or not thanks
If it was not detailed in the job description, you do not have to perform the tests.i was given the job as handyman around the care home but was not aware that i was required to do the pat testing until 2 weeks into the job when i was handed the new pa tester and the relevant paperwork and a video to watch but my question is do i have to take a test or not thanks
There is a course which includes a test at the end. It's one of those multiple choice things where you can have the book of answers open in front of you while completing it.s on the video they gave me kept mentioning a test for pa testing that is all thanks
Battery operated 'pat testers' are useless junk, and with the massive prevalence of Class II equipment now, there is actually very little that can be tested with those battery operated efforts.My biggest concern is the low voltage and current used for the tests. I know there have been some "discussions" about this, and the faults that don't show up at low voltage but which do show up at "mains" or higher voltages.
I thought code of practice stipulated 500vdc my old copy 10.3. Also 612.3.2 states 500vdc.That BattPat thing apparently uses a test current of 150mA for earth continuity - meaning the smallest whisker of wire connected would show as a pass. It's insulation test of 350V is also feeble, as that is pretty much the same as mains voltage.
