522.6.101(v) & 522.6.102
The way that they are written, surface clipped cables which at some point pass through a wall >50mm thick would need RCD protection.
And that unless where they go into the wall is within 150mm of a corner or ceiling, they would also need an accessory there to create the zone running through the wall.
Or, would you argue that as you can see the cable entering the wall, no concealment is taking place?
