- Joined
- 2 Feb 2007
- Messages
- 105
- Reaction score
- 0
- Country
Hi, I've started a new thread to separate this from my previous cooker related questions.
In regard to tidying the cooker ignition and the extractor can I have your opinions of these two options or other options please?
Option 1 is to spur off the ring socket (1) to a switched FCU (2) from this on the LOAD (max 13 amps onwards) it would give switched control of an unswitched 1 gang socket (3) for cooker spark and another (or flex outlet) (4) for extractor. Extractor has it's own integral switches.
This way would keep it neater, but one switch on item (1) for all isolation
View media item 66669
Option 2 is to spur of the ring socket (1) to a UNswitched FCU (2), from the LOAD (13 amps max onwards) wire in a switched FCU (3) to go to the 1 gang unswitched socket (4) for cooker spark (3 amp fuse max for this) , radially wire in (from 3’s SUPPLY) a switched FCU (5) to go to 1 gang unswitched socket (or flex outlet) for extractor (again 3 amps fuse max).
This option gives full isolation switching, but looks more messy and starts to get close to the gas cooker rings (approx 250 between item 5 and gas rings)
View media item 66670
Or of course a better idea, some of the above etc.
Thanks for helping.
Thanks for helping.
