USA toaster to work in uk (nearly there)
30 Sep 2005
Kent
I have a USA toaster/hot dog machine that is a 110volts, 650watts power with a two pin plug.
I know it won't work the normal way buuuuutttt, I have a 230-240v to 110v transformer at work that is big and yellow. We use them to charge a big yellow ambulance at 110 volts.
At the end of the charger plug it has a usa plug outlet, the circle is the earth cable? The large hole is the live and the small hole is the neutral. Now is this the same as the USA and fits the toaster plug (but without the earth)
I have checked websites and the USA plugs sockets live is the small hole.
Now if I plug in the toaster/hot dog machine will it blow or do I have to swap the wires over to make the smaller hole on the charger plug the "live"?
Are you sure the transformer is 110V, if it's a building site type transformer it's more likely to be 55-0-55 volts centre tapped to earth.
You cannot use a US appliance in a UK workplace unless it complies with UK safety standards, which it quite probably won't.
The websites are right. The socket on your transformer is incorrectly wired.
I will take a picture later and show you, I am sure that no more than 110vots will come through it.
That's why I needed to know if my plug would fit and work in it. As for using it in the work place I would bring it home to try it to avoid safety laws
And you're absolutely sure it's not supposed to be earthed, and have a 3-pin plug?
It will work either way round, but it should be the right way round in case there are internal fuses, single-pole switches etc, as those must be in the line, not the neutral.
So you're going to lug that site transformer back and forth?
Steal it?
Buy your own?
Wouldn't it be a lot simpler to buy a UK appliance?
Indeed, but it's still 110V between the ends, and if the item isn't earthed it will be fine.
So here it is, the hot dog toaster. My wife purchased it from the states and I am determined to get it to work either at home or at work regardless of cost.
I know it would be cheaper to buy a toaster in the uk but where would be the sense of achievement and accomplishment by getting one from the USA to work.
Looks as though it's meant to not be earthed. IHNI what standards US appliances have to be built to to not need an earth.
Interestingly, when I think of all the hot dogs I've eaten here, and in the USA, I've never had one where the bun was toasted.
Some US devices use two 120 volt elements in parallel. For the UK market they are supplied with the elements wired in series for 230 operation.
Nostalgia are imported to the UK by Smart Worldwide Ltd Their technical people may be able to advise on whether it can be converted to 230 volt operation.
SMART Worldwide Ltd
SMA House
Homepark,
Langley Waters
Kings Langley,
Hertfordshire
WD4 8LZ
Email: [email protected]
Tel: 01923 290 490
Fax: 01923 290 491
"as it is a two pin system would it matter which way round the plug went into the socket adaptor (regardless of pin sizes i know that they are two different sizes) would it matter which one would live and which one would be neutral?
as i dont know how the US electrical system works? wether the live has to go through the heating element or if it would matter if the neutral went through it as long as it made the circuit?
i may just plug the fecker in and hope it doesnt blow the toaster?
Yes. The live should go to any controls first.
Not possible.
The neutral is the return path after a load.
Try TLC direct electrical wholesalers online they have in there catalogue a range of step down transformers in a range of sizes for different loads and they come with the US 3 pin sockets on them.
I have seen on other forums people who have imported US powertools fitted a Yellow 16 amp plug and run them from a site transformer with no problems.
In the USA Black is the Live or "Hot" wire as they say and white is Neutral green is usually the Earth or "Ground" wire
Not possible.
this shows the usa plug socket as the small hole being the LIVE or Hot Wire.
At the end of the charger plug i have at work it has a usa plug outlet, The large hole is the live and the small hole is the neutral.
would i be right in assuming i would have to make the english BROWN Live Wire the small hole in order for this to work?
then the brown live, powers the small usa "Hot hole" so when i plug the toaster into it press down on the toaster my Weener gets hot and it toasts my buns?
