Another Scout Project
11 Jan 2004
LED Season's Greetings Cards.
The idea is to use a 3V button cell a simple switch and some LED's. The "circuit" will be made with tin foil and I am planning to use red and green LED's.
I know I could incorporate a 555 chip to make it flash, but want to keep it reasonably simple.
Maybe I could get some flashing LED's?
seen them cells in the poundshop, you get loads for a guid, proberly do the job rather than pay loads of money, or maybe get there little novelty things and chop the leds and bits of them
Thought about the pound shop, but I need batts with tabs. There's an ebay chap selling Varta 2032's for 11.99 for 50.
Remaining Campsite Debris?
The idea is to use a 3V button cell a simple switch and some LED's. The "circuit" will be made with tin foil and I am planning to use red and green LED's. ... I know I could incorporate a 555 chip to make it flash, but want to keep it reasonably simple. ... Maybe I could get some flashing LED's?
Do I take it that you've looked around 'craft' suppliers? I would have expected that there would be sources of cheap (and probably very 'flat:-) ) components (LEDs, switches, batteries) specifically designed for the sort of purpose you have in mind?
Thanks John. I started by looking at Hobbycraft. They don't have any electronic components.
Bernard, the LED's are no good voltage-wise, but I'll look at the track. Thanks.
Could you risk using 9 volts from a PP3 battery as they are easy to connect to using two drawing pins in a piece of wood as contacts and a rubber band to press the battery against the pins.
