Just moved house which has an ideal istor boiler. We had the same boiler in out last home and have a british gas homecare agreement as we knew it would be problematic.
We have found that when the hot water was being heated the radiators were hot and that after the hot water had been heated that when initially running the cold water tap the flow would contain very hot water.
British gas agreed with my verdict that the diverter valve needed replacing to fix the radiator issue and they suggested that the thermostatic valve was the likely culprit for the hot water issue.
Both parts have been replaced and the radiators are no longer hot
But still getting hot water when initially running the cold water tap
can you help me understand the name of the part in the attached image as I think it might be the cause or if you have any suggestions, I would really value them.
James
James
