hi
Just been in touch with local planning department and they were useless on giving me adivice.
We are a detatched house and in 2006 we had a side extension built which only needed a planning application on one criteria, ie that the pitch of the house was 4m 30cm so we went over the 4m rule. The extension on the side is a wheelie bin width from the next house and that house forms the boundary. The original extension is set back from the front of the house and the back wall is flush with the back wall of the original property
we want to add a conservatory for the room on the back of it with the wall of the conservatory continuing the wall of the extension and keeping a wheelie bin width path. We will not be covering more than 50% of the original land before the house. The conservatory is less than 4m extending from the back of the extension which is flush with the original house hence meeting that under 4m rule for extending beyond the back of the original house.
We meet other requirements like height of eaves within 2m of a boundary being under 3m etc
I cant see under what requirement this isnt permitted development but the council lady kept going on that building it on the back of an extension changes it. I gave her the example of if we had built this extension larger to project back past the back of the original property and the height hadn't gone over the 4m that would have been permitted development so I can't see why now this separate project would be any different in planning rules as it doesn't go over the heights or back more than 4m from the line of the original property. I can't see any rule where it states you can't build on to an extension.
Please can someone advise?
Many thanks
Hettie
Many thanks
Hettie
