Brown sleeves on switched live cable (lighting)
5 Jan 2008
Berkshire
I did a job in London last year (2012) where the electrican did not put any sleeves on te switched live cable, and took off sleeves where they were on, when I asked him why he said that the regs had changed and that the sleeves were not required on new installations.
Today (Nov 2013) I have had an electrician in, and he included in the quote brown sleeves for the switched live cables both in the light point and in the socket. I told him about the other electrician, and he said that the rules had never changed, sleeves are mandatory.
Who is right and who is wrong? If the job gets inspected I assume it will be the electrician who gets in problems, but I still get hassle for getting in the 'wrong' guy. Question is, who is the 'wrong guy', or are they both right????
Where do 'ideas' like this start?
Even if the fist 'person' was correct, why would he purposely remove them?
Where do 'ideas' like this start? Even if the fist 'person' was correct, why would he purposely remove them?
Goodness only knows! Maybe he not only 'thought' that sleeving was no longer required, but also that it was now actually 'not allowed'?!
Just out of curiosity, is it in the regulations and mandatory or good practice/guidance? :?
I think I must follow the first guy around, rarely find the switch lives sleeved.
But the regs state that the conductors must be identified and that didn't change in 2012!
It's in the regs that they be identified! It's BS though, so if you like to call it guidance you can.
It would probably be of more practical value if the regs insisted not only on the 'identifcation' of L, N andf E conductors, but also 'functional identification'. Although not very commonly used, twin brown (+E) or twin red (+E) leaves one not knowing which is the S/L. On the rare occasions I've had to deal with it, I've actually put a small bit of brown (or red) sleeving over the brown (or red) S/L, to 'identify' it as such'.
Ah, that's interesting.
I do the opposite, i.e. to identify the permanent live - my logic being it is 'liver' than the other.
That would confuse me as I would automatically see the sleeving as indicating a S/L.
Fair enough.
I was talking about in the switch just for information.
Of course at the rose where I have now realised it was being mentioned it would be as you say.
I'll get me coat.
Ah, that's interesting. I do the opposite, i.e. to identify the permanent live - my logic being it is 'liver' than the other.
That certainly would be more logical, were it not for the fact that (as Johnmelad has said) we are used to seeing brown/red sleeving (usually over blue or black) to indicate S/L.
That's why I use a bit of yellow tape to indicate S/L.
Works on both red and brown cables (I have a mixed installation).
