Planing?
18 Sep 2008
Gwynedd
Hi, I will be using a circular saw for cutting for my projects. A bathroom towel cabinet first. If you guys use a circular saw for long cuts do you make a general cut and then take it to the mark with a plane? The reason I ask is when using the saw the width of the cut itself is quite wide and so that could throw a measurement out by a mm or 2.
a bathroom cabinet can be 2mm out it wont matter
plan your cabinet lets say its 200mm deep you cut one or more strips 200mm deep
mark the board at 200mm lay the saw with the blade on the mark
measure from the saw base back edge to the board edge
lets assume thats 300mm you mark 300mm in pencil on the tape
you then mark the board with 2/3 or4 marks lay your baton on the mark and clamp
you can do this several times and you will be within 0.5mm
if you get a track/plunge saw its 10 times quicker :D
Hi again guys. Can I just return to this question.
I've been using 8"x1" with this open fronted bathroom cabinet I'm putting together. I'm putting a couple together so thought I would use the circular saw to make cuts. My cuts are still a little wobbly and so edges that butt against each other aren't exactly straight. Would you guys use a sander, a plane, sandpaper, or what to get the edges straight for nice tight butts?
you need a chop/ miter saw to get real accuracy
8" planks are a bit wide and may cup
you would be better off with 4x1 or 5x1" or a combination off both and flip the grain and glue together
if you already have the timber keep it out off damp or hot situations untill fixed together in a box shape
i cut half the pencil line out ;)
That would leave you very minutely short. :eek:
you draw a pencil line on the the exact mark so the center off the pencil line is central to the mark on the tape
of course if you mark "off center" then you take that into account :D ;)
Pencil line is thickness of mark usually, so cut thru it leaves it short. Exception is when using a marking gauge where line is much thinner than pencil.
if yoy have a guide on your saw then use it.but you do need to be secure and confident in what your doing.if no guide then work out the size of cut you need to do,turn the machine over(making sure its not plugged in ;) )measure from the blade to the edge of the base plate,then transfer this measurement onto your work,then clamp a straight edge to the line you have marked.then cut the timber,this way you shoud be pretty much spot on every time.
hopefully ive explained that well enough ;)
also bear in mind the type of pencil you use.a hb will start off fine but within a short time the run will get thicker.i personally only use 2h pencils,was taught this yonks ago.the point lasts longer and gives you a crisp line of sight.
Thanks again, I'm cutting much straighter and accurate lengths now. The clamped straight edge worked perfectly even when I cut an inch from a 2ft wide piece of ply.
Interested in glueing smaller widths together to make one piece. I assume long clamps would be needed? And what type of glue would be used?
