I am totally rewiring the entire house as we have ripped the whole house apart.
I need some info for the bathroom.
I will have a light unit on the ceiling. Can the wiring for this be run as a continuation of the wiring run for the rest of the lights upstairs or does it have to be a separate supply?
The switch is a pull cord. Can I use single pole or does it have to be double pole?
If double pole does the main wiring connect to the switch and then run to the light unit or will the wiring go to the light unit as a normal room and drop over to the switch?
The same question for spotlights over the mirror?
I have a whirlpool bath. This obviously requires a power supply. I understand it has to be its own individual supply to the Consumer Unit and RCD protected, but where can I put a fuse spur in the bathroom for it?
That's it for now, any replies will be welcome.
