Oooh you beach
people like to make things difficult.
Buy push fit tees and use them, I regularly go to houses that have 15 year plus pushfit in them.
Also if you over tighten a olive it will cut into the plastic, also compression has a much greater chance of leaking after getting hot/cold/hot/cold. THE FITTINGS ARE DESIGNED FOR THE PIPE.
You could have if you really wanted to go over board placed a manifold in the middle of the house (either accessible or above the floor) ran 22mm to that direct from the boiler. Then ran continuous lengths of 15mm from the manifold to each rad. Of course that would be pointless and expensive... but some people like this as it makes them feel their system is special (as special as rads and pipe can be anyhoo)
Nobcon, those are the ramblings of a man who clearly doesn't understand water carrying systems and how they work.
Are we going to have another 20 pages of your ridiculous ramblings?![]()
So Nobcorn, why is compression fittings on gas outlawed when inaccessible I.e., under floors.
You really are turning into this forum's biggest tard.
Also the season for fun and games Charn.
Come on nobby. Why are compression fittings not allowed under floors with gas? Surely a superior fitting would be fine?
Why are fittings with prongs allowed on gas under floors?
Hhmmmm. .....![]()
such an idiot.
Actually I use copper as a rule but have used push fit and probably will do again. As long as it is installed correctly and pressure tested properly then it is a good reliable system.
Now burying it in screed is a different matter as it is for copper. If I have pipework that needs to be installed in a screed, I use uninterrupted plastic pipe in conduit to comply with regs.
But it's christmas and I have some valuable time off, which is better spent else where then trying to argue the toss with you nobjockey.
Happy new year![]()
