Hi
My problem is that when i run the hot tap the boiler fires up, the rad flow gets hot and the DHW pipe only gets warmish. After reading various posts it is likely to be the diverter valve or something associated with that. (please correct me if i'm wrong). On the attached image the motor is operating the mechanical parts i can see and switches from up to down as it should. I'm guessing now that it is something internal like the diaphragm i've also read about. Could anyone provide suggestions regarding this please? Also can i overhaul the diverter, do i need to replace it or can i replace the diaphragm. I have heard its a nightmare to change but i'm happy to have a go.
Thanks for reading
Shamus
[/img]
Thanks for reading
Shamus
[/img]
