lighting circuit or rings main, depending on rating but it looks like I will never know. I'll probably use crimping for the rings main as a 30A choc block is much more expensive in comparison.
There a number of differing sizes of choc blocks, you will not see a rating printed on them, it's much a case of commentators eye. You gets used to using them and tell just by looking if they are suitable.
It can be debated if crimps are cheaper than choc blocks, as you will need to purchase a crimping tool to make the joint and to do this joint securely you would want to heat shrink it also, which would require heat shrink sleeve and a heat gun.
15 amps.Here's a picture of the size then. What do the experts reckon is the current rating?
I keep saying it - solid conductors should not be crimped.
Least of all by someone who doesn't seem to care.
