Old fuse board with fuse wire...
26 Feb 2005
Gwynedd
I have three fuse boards in the new abode, one of which has fuses with fuse wire in them. Is there any reason particularly to get it changed to a modern one, and if so, why?
Just interested,
The fuse board in question is fed from another, rcd-protected, consumer unit. So, is that sufficient?
The only reason for swap would be if it was unsafe or if you altered, extended, installed circuits to the board that meant they would require an upgrade of protective devices!
