Indeed - which (as above) really should be done under the worst possible environmental conditions (but you'll probably have to wait for them to arise )
Wrapping a wet cloth around it and pooring on a watering can should give sufficient environmental conditions short of a full flood (but then most of the South West would bond their curtain poles!).
Or you can always replace the bit that goes through into the garage with an insulated section.
Water mains entering a building should not be on the outside anyway.
That is true for the primary supply to a property, but is not invariably the case for 'secondary' supplies to outbuildings. In any event, this particular discussion seems most commonly to arise in relation to metal oil pipes, connected to outdoor metal tanks which are just about held above ground level by some sort of stand/plinth.
